Gas pedal
Old Apr 30, 2004 | 12:05 PM
BigTex's Avatar
Exactly what pewterZ71 said. Pull off the TB. You'll probably see EGR residue on the back of the blade and around the sides. Clean all this buildup off with a rag and carb cleaner or some other strong solvent. Then LIGHTLY polish up the area around where the blade closes with some fine steel wool. This objective isn't to remove material, just make a tad better fit.
Old Apr 30, 2004 | 03:22 PM
JSmith's Avatar
I will say that after polishing my TB, the problem takes longer to return and doesn't get as severe. Just a thought.
Old Apr 30, 2004 | 04:32 PM
yeary03SS's Avatar
They make a spray that is specifically for throttle body cleaning. I got some made by 3m, but i'm sure there are many others. It may just be carburetor cleaner with a different name and marked up price???? It was about $5.
Old Apr 30, 2004 | 05:56 PM
JSmith's Avatar
I've been using Goodwrench top engine cleaner.
Old Apr 30, 2004 | 07:27 PM
KeukaZ71's Avatar
i have to clean mine about once or twice a year.
toothbrush + carb cleaner + rag = nonsticky pedal
Old May 1, 2004 | 10:49 AM
tranzfourmd's Avatar
okay for lack of knowledge, anyone got a pic of the specific screw that I should adjust. Im sure I could go out and find a number of them to crank at, but I want to make sure Im movin the right one. If anyone can snap a pic it id appreciate it. Ive got to get this done before it causes any further problems! Thanks for all the info!!!
Old May 1, 2004 | 11:00 AM
FILE's Avatar
Thanks your replies guys.
Pimpinpete
43
Dec 22, 2017 08:13 AM
bearden86
26
Nov 15, 2015 03:58 PM
turbo6c3
Oct 5, 2015 06:11 PM
sTNT971
Sep 26, 2015 04:22 PM
GM1697
Sep 9, 2015 10:31 PM
