Fuel Sender part #?
Old Aug 14, 2005 | 12:02 PM
XLR8NSS's Avatar
Adkoonerstrator
Default Fuel Sender part #?
I've searched around a bit and can't find a part number for just a fuel sender. Anyone got it?
I guess I'm going to fix my bad gas guage so it stops bouncing around all over the place, get's a little annoying seeing the low fuel light keep coming on with a full tank.
BTW, the truck is a 2000 if that makes a difference.
Thanks
Old Aug 14, 2005 | 12:09 PM
GoldenVelvet's Avatar
I have the same problem.... Im just to poor to fix it untill it becomes untolerable, and right now its mearly anoying.
Sorry, I dont have the part number..
Old Aug 14, 2005 | 12:10 PM
FarmerBeau's Avatar
Sexy Party Mod
Ill give my Buddy a call and get back to you. Hes not at work today so if nobody else chimes in, ill get back to you tomarrow. I wish i had the funds to pay for that and all the other caca that i wanna do. Oh well. Good luck.
Old Aug 14, 2005 | 12:19 PM
The fuel sender is part of the fuel pump, and can not be purchased separately.
Checkout GM Parts Direct
The part number for the pump module is 25345026 or 25176865 depends on the type of pump in your vehicle.
Old Aug 14, 2005 | 12:40 PM
FarmerBeau's Avatar
Sexy Party Mod
Are you sure?
Old Aug 14, 2005 | 12:44 PM
FarmerBeau's Avatar
Sexy Party Mod
I have heard that if you go ahead and drop the fuel tank, you can somehow clean the connection of the wiring harness and it sometimes works. It might save you money as to try it but it also means more labor and a possibility of dropping the tank twice. That would kinda suck.
Old Aug 14, 2005 | 01:20 PM
Originally Posted by FarmerBeau
Are you sure?
Yes, I had to replace my fuel pump a couple of times, because of dirty gas. The pump cost me $250 from the dealer. I did notice the float (sender) has two electrical pins that slides on a potentiometer, this could be your problem if the electrical pins become weak and lost their contact. When I replaced my pump I went ahead and cleaned the connector with some electrical cleaner.
Old Aug 14, 2005 | 01:30 PM
XLR8NSS's Avatar
Adkoonerstrator
Yeah, it's a potentiometer. I might try to clean it and see if that helps.
I've read that people used to be able to buy the sender seperately for $80-$90. If they changed it so you have to buy the complete module that would suck but, it wouldn't surprise me.
Thanks guy, I'll keep an eye on this post for more info.
Old Aug 14, 2005 | 03:41 PM
99Silver6.0's Avatar
XLR8,
Sensor, fuel level:
99-01 25314460
02-03 25345176
Those should be it. Unless they superceded with new numbers.
Old Aug 14, 2005 | 09:20 PM
XLR8NSS's Avatar
Adkoonerstrator
I will try it out.
Thanks
