Fuel Pump- Stock or Upgrade
Old Mar 22, 2007 | 01:29 PM
Possessed666's Avatar
Default Fuel Pump- Stock or Upgrade
I think my fuel pump is about ready to take a crap. So I had a couple questions regarding fuel pumps and any help is appreciated.
I currently do not have any mods that would require a high performance pump, but will be upgrading in the future as funds allow. (Supercharger, or turbo, or maybe just a cammed 6.0)
My questions are these:
Would you recommend a pump other than stock until any of these upgrades are done? Which pump would you recommend?
If I was to put a HP pump in my truck, would I have to change anything else?
Would my regulator keep the fuel pressure at stock specs until I need more?
Obviously I am fairly new to computer controlled injection systems, so any help or input is appreciated.
Old Mar 22, 2007 | 02:10 PM
xsports33's Avatar
what leads you to believe that your fuel pump is ready to go?
Old Mar 22, 2007 | 02:52 PM
Well, it may not be. Usually it started real quick, but as of late, it is slow to start. It has to crank for a couple seconds before firing.
Old Nov 21, 2007 | 08:54 AM
LJO's Avatar
LJO
Check the fuel pressure regulator. Pull the vacuum line off and see if fuel comes out of it, if so replace the reg. Or check it with a vacuum pump, if you want to be really thorough
Old Nov 21, 2007 | 10:11 PM
ap2002's Avatar
I would NOT put a stock pump back in there, upgrade to a walbro and it will be alot cheaper and more dependable for you mods later on...
Old Nov 21, 2007 | 10:18 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Always upgrade!
5.3Okasai
Mar 9, 2022 01:07 PM
OHsixLS3
Dec 27, 2016 09:30 AM
76k10chase
Jul 17, 2015 01:48 PM
black6spdz
Jul 16, 2015 01:32 AM
4B11T
Jul 13, 2015 03:48 PM
