fuel pressure regulator on 2002 denali?
Old Oct 1, 2005 | 10:15 PM
Blackdog76's Avatar
Default fuel pressure regulator on 2002 denali?
I am doing a swap with a motor from an 02 denali and I need to know if the regulator is mounted on the motor or is located in the fuel tank with the sender.
Old Oct 1, 2005 | 11:24 PM
The fuel pressure regulator is located on the driver side fuel rail.
Old Oct 2, 2005 | 09:28 AM
Mort's Avatar
Cool
Yup , which is fine if you are putting it in an 99-03 truck. The '04 and newer have a returnless fuel system with the regulator in the tank.
Old Oct 2, 2005 | 04:26 PM
Blackdog76's Avatar
On the return side?
Old Oct 2, 2005 | 05:00 PM
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by Blackdog76
On the return side?
In the center of the driver's side fuel rail on the intake. It's round with a vacuum hose going to the top of it
Old Oct 2, 2005 | 05:15 PM
BadAssChevy327's Avatar
whoa whoa whoa not to hijack by no means and this might help you also . how do you adjust your pressure on 04 and up . also what are the major downfalls to this and psotives
Old Oct 3, 2005 | 12:07 AM
Blackdog76's Avatar
So this brings me to my next question. I have a walbro 255 intank pump. Is the stock regulator going to be OK with that?
Old Oct 3, 2005 | 01:43 AM
budhayes3's Avatar
PT's Slowest Truck
04 and up don't have an external regulator, it's a returnless system. As far as adjusting air/fuel ratio or injector duty cycle or anything like that, you would need the proper tuning software to do so.
Not sure about the walbro with the factory regulator...you'd probably want to contact walbro on that, I'd assume that they'd have their own heavy duty style reg, but I'm not sure.
noproblems209
Aug 10, 2015 06:57 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
slowlsx
Jul 13, 2015 04:18 AM
