front wheel hops while turning
my front driver's side wheel will hop or skip when i crank the wheels all the way to the right when turning into a parking spot. it does not do it when i turn left. what causes this?
i wonder if the brake is sticking. i will check. we do get alot of debris on the roads here in the winter time
can't remember if i heard any noises or not. i will have to check it again. i know, dumb me for not paying attention to my vehicle. it seems to have so many noises coming from all sorts of different problems i almost feel like trading it in for a GMC
had a similar problem with mine, had to replace the ball joints and the wheel bearing. shocks were toast too as a matter of fact... but the expensive unit was the wheel bearing primarily 'cause my trucks a 3/4 ton.
if you lift your front end off the ground see if you can get any movement outta the wheel (in/out obviously)
or, maybe it is time to trade in the truck with all the stuff that is wrong with it now.
i do remember hitting a HUGE pothole about a month ago with my front drivers side tire. would that of caused the problem?
the day after i hit the pothole, there was a guy on the news that night on the side of the road with a blownout tire in the same exact spot i was. i bet he hit the same pothole.
i will check it soon, thanks.
now i am thinking that it might be my front brake is stuck. it made like a sqeaky sound when i pulled out of my parking space this afternoon.
the wheel has not hopped in a few days.
03regcab sierra
20
Aug 3, 2015 12:11 AM
