front end conversion
Old May 19, 2013 | 11:21 PM
asap216's Avatar
Default front end conversion
well my truck was hit and my front end is pretty banged up so while i replace the entire front end i want to do the 06 chevy front end with the hd hood. i know i have to do both fenders, hood, bumper, valence, head lights and the turn signal lights, grille and emblem. My question is the more i keep looking this up it keeps coming up the where the bumper brackets bolt up its different and must be welded. Anyone here do the swap on a truck similiar as mine can verifiy this does everything bolt right up? And yes i used the **** outa the search button i just want to verify everything bolts right up to make the install go smooth.
Thanks, Abel
Old May 21, 2013 | 12:37 AM
asap216's Avatar
anyone?
Old May 21, 2013 | 12:40 AM
Wilde Racing's Avatar
How do I change this text
I've done a 2000 to 2005 conversion a while ago I can search for it in a bit...
Old May 21, 2013 | 12:45 AM
https://www.performancetrucks.net/fo...2005-a-370301/
Old May 21, 2013 | 01:05 AM
asap216's Avatar
i actually found that thread when i was searching and that's how i discovered the mounts are different. Did you have to make your own mounts or how did you go about using the bumper?
Old May 24, 2013 | 10:36 AM
I can't find any of the build pictures on my computer, but "I THINK" I just drilled a hole through the frame for the newer style mounting bracket. I remember it wasn't too difficult to make it work. The hardest part was the drivers side fender, lots of wires...
Old May 24, 2013 | 11:47 AM
La Grey 1's Avatar
you will have to cut the tips of your frame if you have a 99-02 not on a 03+ ive done it before but i have no pics to post
JordanH
Feb 28, 2017 07:22 PM
Corvette454l88
Sep 1, 2016 01:24 AM
5.3Caprice
Nov 7, 2015 08:56 PM
vmaxpro
Aug 10, 2015 07:25 AM
Offroadunleashed
Jul 20, 2015 02:25 PM
