Freaking Fuel gauge! ( Yes i searched)
Old Jun 29, 2015 | 09:21 PM
djquik88's Avatar
Default Freaking Fuel gauge! ( Yes i searched)
Pulling my hair out guys.. I bought an '04 Avalanche Z71 . The fuel gauge and the oil pressure gauge wasn't working so I assumed it was the stepper motors...I was wrong. After replacing all of the steppers, they still do not work. I dropped the tank today to replaced the sending unit with a new AC delco unit. Upon pulling the old sending unit out, I noticed the float arm was not on the sending unit. I got really happy thinking some douche nozzle replaced the pump with no arm. Well after installing the new pump , I hopped in the truck and started it up...freaking gauge still wasn't working! Low fuel light is still on, low fuel warning on the cluster too... any ideas wtf else it could be?
Old Jun 29, 2015 | 10:35 PM
djquik88's Avatar
OK.. Just filled it up and the fuel light is off and I'm not getting the low fuel warning... But gauge still doesn't work..
Old Jun 30, 2015 | 07:42 AM
06murder's Avatar
could be cluster messed up. gm clusters suck!
Old Jun 30, 2015 | 01:36 PM
Gadgetized's Avatar
Do you have the ability to check with a scan tool? If not, you can get the Torque Pro App for Android for $5, and the wireless ELM327 dongle for about $10(IIRC). That will tell you if you are getting a different reading to the cluster.
Old Jul 3, 2015 | 09:43 AM
djquik88's Avatar
Thanks guys. Im thinking its the cluster too. I did order a wireless dongle also.. I should have had one a long time ago! Ill let yall know what I find out.
Old Aug 15, 2015 | 10:21 AM
Badasschevillac's Avatar
My oil pressure gauge wasn't working either (stuck at 80 psi or 0) ended up being the sending unit. Quick, easy, cheap fix too (easy if you have small hands, sending unit in awkward spot on back of motor)
thunder550
Oct 8, 2015 04:53 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
