fire extinguisher
Old May 13, 2008 | 02:28 PM
charcold-bowtie's Avatar
Default fire extinguisher
I guess this is the best section for this... With the soon addition of a turbo i got around to mounting an extinguisher. Ive seen too many threads on burndowns so it seems like cheap insurance. It came out pretty decent and was easy. I used the back seat studs and nuts. No modification just essentially added a few washer, with a bracket. It is 3 inch C iron with washers space to fit the studs. It is still easily removed, just remove the extinguisher and a deep socket will still get them. It is mounted at a tiny angle to clear the sub box. It also retain the facory cover, u just have to remove a lip off of it.
Old May 13, 2008 | 02:55 PM
kbracing96's Avatar
NIce, one of the best mods you can ever do!
Old May 13, 2008 | 03:27 PM
Y2KLimited's Avatar
since my tahoe was a rolling bag of destruction, I usually carried one in it 'just in case' Never mounted it all nice, just threw it in the cargo net on the back of the passenger seat.
One of those things that you hope to never need, but sure can save your *** if you ever do.
Old May 13, 2008 | 03:32 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Looks good and in a good location to get at easily. I have mine right next to the consol on the passenger side where I can at it and go.
Old May 13, 2008 | 03:52 PM
thunder550's Avatar
High on diesel fumes
Yep, good insurance. I never mounted mine, it just lays in the back seat. I've used two so far.....
Old May 13, 2008 | 07:42 PM
BigCountryx's Avatar
I've got mixed emotions, if my trucks on fire I don't know if I want to put it out or throw more gas on it. lol
Old May 13, 2008 | 08:05 PM
terravast4's Avatar
Very smart, just make sure you routinely check the pressure because those little ones are notorious for leaking. also one more thing....make sure your extinguisher is rated for your application all extinguishers are different. they are rated a,b and c not sure from memory what they correspond to but do your research and be sure you got the right one or your truck just might burn down in front of you with an empty extinguisher in your hand.
Old May 13, 2008 | 08:29 PM
2005 Silverado's Avatar
SPAM HUNTER
i got me one!...for some reason my grandparents had 4 small ones...i think they had one in each car...then they sold most of them...so yeah...i snagged one!
Dustin
Old May 13, 2008 | 08:49 PM
Silverado_13's Avatar
Self proclaimed VILLAGE IDIOT
I hate to rain on everybody's parade, but unless you have a Halon fire extinguisher you may as well not have one at all. Chemicals used in regular fire extinguishers can and will damage all metal and electrical components under the hood.
Old May 13, 2008 | 08:51 PM
sierraboy's Avatar
14 Second Truck Club
I HAVE MINE BEHIND THE BACK SEAT
SINCE MY TRUCK ALMOST CAUGHT ON FIRE
https://www.performancetrucks.net/fo...ALMOST+ON+FIRE
