Fast blinkers
Old 12-17-2018, 12:52 PM
Still moddin'
Reckless's Avatar
Default Fast blinkers
I added LED front blinkers and now they blink fast ( as if when a bulb is out). Everything is operational, just blinking fast????
Any remedy to return to normal speed?
Old 12-17-2018, 01:05 PM
FFDP's Avatar
Use the google.
Pretty common issue.
https://www.superbrightleds.com/blog...rflashing/275/
Reckless (12-17-2018)
Old 12-17-2018, 01:17 PM
Still moddin'
Reckless's Avatar
I figured there would be something out there. Big thanks!
Old 12-17-2018, 03:54 PM
someotherguy's Avatar
Dunno if your 2000 uses the combo flasher like my 2006 does, if so you need the Novita LM487 - sumbitch is about $50 now though, man the price has really come up - I think I paid $35 for mine a couple years ago.
You can also hack the flasher module by cutting one leg off the IC for the turn signal side. Super easy. You won't get "bulb out" hyperflash warning anymore but pretty sure that functionality is lost no matter how you resolve switching to LED signals.
I had hacked the regular flasher on an older (GMT400) truck with success, and discovered the combo flasher a GMT800 uses has the same IC in it. I mentioned it over on Silverado SS forums and someone else tried it, says it works fine. Here's his pic detailing leg #7 that you cut on the IC:
Richard
Old 12-17-2018, 07:50 PM
Richardman1992's Avatar
I got my flasher relay from super bright leds, I don’t think it was more then 10 or 20 bucks. It is a combo in my 01, so I’d assume the same as 00 and 06
Old 12-17-2018, 11:47 PM
100% Redneck
RedXray's Avatar
Received 1,331 Likes on 793 Posts
I did the flasher mod clipping pin 7.
Had to use a magnifying glass and use a small pair of surgical scissors to clip the pin... it's that tiny!
It flashes slightly faster than normal but nothing like the hyper flash as before the snip.
Old 12-19-2018, 05:50 AM
bobfig's Avatar
i just swapped my module out with this one and no issues with fast blink as the timer isnt ran off resistance.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Old 12-19-2018, 10:00 AM
Still moddin'
Reckless's Avatar
I scored the EP29 module from O'Reillys for like $15 in stock Works fine!
Old 12-19-2018, 10:50 AM
Good deal. So no wide combo flasher on your 2000 model then?
Richard
Old 12-19-2018, 10:55 AM
BudRacing's Avatar
There are also LED turn signals made with built in resistors to mimic the load from an incandescent bulb.
guero68
06-13-2015 05:35 AM
BLKZ71
01-09-2009 09:55 AM
sexyvic1
02-06-2005 03:39 PM
SnakeOiler
09-16-2004 08:34 AM
F8L Z71
04-23-2004 12:29 AM
Quick Reply: Fast blinkers
