factory security system on 2002 tahoe
Old 12-29-2006, 12:46 PM
nvrstsfd23's Avatar
Two more questions.
One is it possible to disable the security system so I won't have to worry about it or is that not a good idea.
Two when we bought the car it had a spare key with it that was not a gm key so it had no resistor in it or anything but it worked in the truck. With the passlock I thought that it had to be a key from the dealer. We don't use that key in the ignition bc I wasn't sure. I know it was just one of the cheap keys from lowes that was the extra.
Old 12-29-2006, 12:56 PM
Nick™'s Avatar
there is no resistor on the truck, it's a different system. You can use a program such as HP Tuners (the same program you use for your car) and you can disable the VATS (vehicle anti-theft system). I have done this before on a friend's truck and it worked perfectly. just disable the damn VATS and be done with it, your local tune shop should be able to do this for you or you could contact any of the custom tuners in the sponsor section.
Old 12-29-2006, 01:39 PM
TurboJohn6's Avatar
Originally Posted by nvrstsfd23
Two more questions.
I believe Nick answered your question. That is probably why the spare key that you have worked. I was under the impression that GM still used the Passlock System in your truck (02). That key would not work in my truck (00) because it would need that resistor. Your problem still sounds like something in the Anti-Theft System though. You could always do what Nick said. I personally would rather fix the problem. Good luck!
Old 12-30-2006, 10:12 PM
nvrstsfd23's Avatar
thanks for all you help guys. I think we will just disable the vats system. I have a friend that could do that for me probably. I'm not really worried about fixing it we have tried enough. I don't want to sink any more money in it than I have too.
SLOPONY
20
10-18-2016 06:05 AM
Corvette454l88
09-01-2016 01:24 AM
1SlowHoe
08-05-2015 12:58 PM
InsaneDomestics
07-27-2015 02:42 PM
bsgiffor
07-19-2015 11:14 AM
Quick Reply: factory security system on 2002 tahoe
