exhaust manifold bolts
Old Aug 31, 2011 | 11:45 AM
Steve-O-08's Avatar
Originally Posted by TX Tahoe Z71
Same here. But I did give them a good soaking for a week with Kroil penetrating lube before the header install. I could have broken them loose with two fingers on the wrench.
Stock bolts here too. WD-40 on them a few days before the header install and they came right out. Had them out again when I did my engine swap and didn't even hit them with WD, no issues at all.
Old Sep 11, 2011 | 04:50 PM
LJO's Avatar
LJO
Just got my 05 Denali. Has the rear most two bolts missing on both sides. Just loosened the 4 on the passenger side that were still intact, and luckily didn't break them. I'm going to stud and nut them all with high quality studs and nuts ASAP.
Old Sep 11, 2011 | 06:05 PM
scooter k's Avatar
The best way I've found getting the bolts out that are broken flush is to use an arc welder and welding a nut to it. Mig welder doesn't work that well but arc welder does. We don't even attempt to drill them anymore.
Old Sep 11, 2011 | 06:11 PM
1Bear's Avatar
Two of the bolts, one in each end of my driver’s side manifold were snapped off. Just the heads were popped off, so they came out easily. It’s been six years since I installed the headers using factory bolts, and every one is still intact.
Old Sep 13, 2011 | 10:31 AM
ReallySatisfies's Avatar
Just noticed the exhaust leak pattern on my '99, bolt heads still look attached.
Where should I get good replacement bolts?
Is there a gasket I need to replace as well?
Old Sep 13, 2011 | 10:44 AM
Atomic's Avatar
I have a gauge for that
I got some grade 10.9 allen head bolts from fastenal, seem to work great, just be sure to use some antiseeze
Stainless Works
Apr 10, 2016 04:34 PM
Stainless Works
Aug 4, 2015 12:56 PM
fat tony157
Jul 16, 2015 12:35 PM
Suburban2500
Jul 13, 2015 09:57 AM
