Engine harness ground locations - Who can name every location?
Old Apr 23, 2009 | 09:43 PM
hirdlej's Avatar
Default Engine harness ground locations - Who can name every location?
Quickly, who can name every engine harness ground location for the engine harness? I just want to give everything a good once over Most specifically, where is the ground wire located that's for the 02 circuit on the pass side? The more info you guys could provide the more appreciated I'd be.
Thanks in advance.
Old Apr 23, 2009 | 10:26 PM
00ChevyScott's Avatar
Wearin' da big hat
Off the top of my head. 1 main ground wire on drivers side of block, and 2 grounds on the back of the block for o2 sensors. This was on my 2000 wire harness.
Old Apr 23, 2009 | 10:36 PM
hirdlej's Avatar
Does the pass side 02 sensor ground hook up to the top of the block on the pass side? I tried cleaning and reattaching that one already. (The one that's to the left of the oil pressure sending unit)
Old Apr 23, 2009 | 10:41 PM
Wearin' da big hat
yep, thats where that one goes.
Old Apr 23, 2009 | 10:48 PM
dlt76028's Avatar
three on top and two on drivers side block
Old Apr 23, 2009 | 10:50 PM
Wearin' da big hat
I only had one on the side of mine, and now that I think about it, I might have had 3 on the back. I marked all the heads of the ground bolts with a sharpee when I did my motor swap.
Old Apr 23, 2009 | 10:56 PM
dlt76028's Avatar
on the side i had a big wire and a little wire that went on the same bolt.
Old Apr 24, 2009 | 02:19 AM
thunder550's Avatar
High on diesel fumes
Me too. One is the battery ground IIRC.
ARC
57
Feb 21, 2022 10:54 AM
85SS/85GN
Jul 22, 2015 12:48 PM
01sierraon22s
Jul 8, 2015 11:26 AM
GreyChevy
Jul 7, 2015 08:57 PM
