Engine harness ground locations - Who can name every location?
Quickly, who can name every engine harness ground location for the engine harness? I just want to give everything a good once over
Most specifically, where is the ground wire located that's for the 02 circuit on the pass side? The more info you guys could provide the more appreciated I'd be.
Thanks in advance.
Most specifically, where is the ground wire located that's for the 02 circuit on the pass side? The more info you guys could provide the more appreciated I'd be.Thanks in advance.
Does the pass side 02 sensor ground hook up to the top of the block on the pass side? I tried cleaning and reattaching that one already. (The one that's to the left of the oil pressure sending unit)
ARC
57
Feb 21, 2022 10:54 AM
85SS/85GN
Jul 22, 2015 12:48 PM
GreyChevy
Jul 7, 2015 08:57 PM
