Electric Fans - Pin 33
Old Apr 8, 2009 | 02:08 AM
  #31
Wheatley's Avatar
Truck Sponsor
it does now
Originally Posted by BlackGMC
I am pretty sure the 03 and 04 are the same. I did it on my 04....
Here is the thread.
https://www.performancetrucks.net/fo...ighlight=efans
Hopefully your using EFI Live, cause HPtuners does not have the AC pressure adjust needed to control the second fan correctly....
http://www.hptuners.com/forum/showthread.php?t=8858
Old Apr 8, 2009 | 11:46 AM
  #32
midnight_bowtie's Avatar
Originally Posted by CashDudeHomie
Nonnie, how do you do it on a 99-02? I have the 03+ diagram, but I can't really read it. I have had some 05 fans for like a month just sitting at my brother's house because I have no idea how to hook them up. I want to use both PCM pins because I have the new HPTuners beta version. Please help!
One of my impala fans gave out and I want to step it up to the 34" rad w/ the bigger efans. Would really like to do this right this time around.
Old Apr 8, 2009 | 02:20 PM
  #33
SilverDog's Avatar
Here are some diagrams I have.
#1 similiar to Nelson Harness
#2 similiar to 05+ Gm Harness
#3 05+ Gm Harness
#4 05+ Gm Harness, I Modified for 2 fuses
The first one uses the ac as a trigger while the other three use the two pin setup. Not sure who uses #2.
Old Apr 8, 2009 | 03:11 PM
  #34
nonnieselman's Avatar
Do yall just need the harness info???
I used this diagram.
run the wire thats suppose to go to the AC ground to the PCM pin 33 and activate it in the tune and Vola..
Old Apr 8, 2009 | 03:24 PM
  #35
Thanks man. installing the 34"rad and fans shouldn't be too much of a hassle if at all but wasn't sure how to get them running. I didn't want to use the same wiring as now and have them running constantly. Did you make your own harness or mod one?
Old Apr 8, 2009 | 04:27 PM
  #36
CashDudeHomie's Avatar
We're still trying to figure out if you can use pin 33 on a 99-02 truck...
Old Apr 8, 2009 | 04:35 PM
  #37
I made my own..
you can use Pin 33 and 42....
on EFI Live you go to System > A/C > Parameters
{G0106} A/C Auto Recirculatoin - Fan #2 Control
Then go to System > Fans> Parameters
{G1203} Type of Fans Fitted To vechicle - Series Parallel Fans
This is how the stock Fbody tune is setup..
here is my Fan settings BTW
I know HPT is different, but you get the idea?
Old Apr 8, 2009 | 04:36 PM
  #38
Old Apr 8, 2009 | 04:39 PM
  #39
KySilverado's Avatar
I think the point is that you posted a wiring harness diagram that won't work using pin 33.
Old Apr 8, 2009 | 04:42 PM
  #40
This one works..
It grounds the relays.
