Electric Fans - Pin 33
Old Apr 8, 2009 | 04:53 PM
  #41
KySilverado's Avatar
So from that diagram, instead of splicing into the A/C clutch as it states you ran that to PIN 33 of the PCM?
Old Apr 8, 2009 | 05:01 PM
  #42
nonnieselman's Avatar
I promise im not completely dumb....
i wasnt even payin attn to the diagram. But yes run the wire thats suppose to go to the AC ground to the PCM pin 33 and activate it in the tune and Vola..
Old Apr 8, 2009 | 05:46 PM
  #43
Not insulting your intelligence, just clarifying for the guys that are wanting to do it.
Old Apr 8, 2009 | 06:27 PM
  #44
i tried to modify the diagram, but it turned out horrible.
Edited the other post....
Old Apr 8, 2009 | 06:43 PM
  #45
For the question of this working with 02 pcms.... there have been a lot of diagrams posted on wiring. I haven't traced them all out. The original GM wiring diagram thats been posted is what I used and I know it works the way GM intended them to work. Not saying the others posted don't.... It's not the wiring diagram thats really important. It's will the 99-02 PCM control pins 33 and 42 and it appears it does from Noonies' experience.
Old Apr 8, 2009 | 06:57 PM
  #46
Its nonnie... JK..
The Fbodies have the same setup with 3 relays and pin 33 and 42
i copied and pasted My buddys 99 Trans am stock settings to my tune to get an idea how GM has it set.
Ive made harnesses, installed Efans, Tuned my 2000 with a 02 pcm.. my buddy's 04 Silverado, a 03 Tahoe, and adjusted my buddys 99 Trans Am Efan settings..
So yea it works
Anyone can PM me if they need help with this.
Old Apr 8, 2009 | 07:01 PM
  #47
Coban's Avatar
So this is not correct?
Originally Posted by Derek @ EDO
The AC clutch engage signal wire is not activated with a ground.. It activates with +.
An older style harness would have to be rewired to accept a ground activation for both low and high speeds. Ive built a few like this, I use the GM schematic and its indeed different from the older clutch activated harness schematic.
Derek
Old Apr 8, 2009 | 07:12 PM
  #48
Whippled 496's Avatar
Are the 05 fans two speed fans as in do they have 4 settings they operate in?
fan 1 - low
fan 1 - high
fan 1 and fan 2 - low
fan 1 and fan 2 - high
...what are the run speeds of the fans is what I am asking i guess?
Old Apr 8, 2009 | 07:23 PM
  #49
fan 1 - low
fan 1 - high
The fans dont matter.. its the relays that control the speeds.
with this diagram...
Read the bottom of the diagram
You will have Fans 1 & 2 on low speed- Fan 2 on high speed- or Fans 1 & 2 on high speed.
Old Apr 8, 2009 | 07:47 PM
  #50
Its nonnie... JK..
Sorry I even spelled it wrong below again and fixed it
What Derek posted is absolutely correct.
fan 1 - low
fan 1 - high
Just as Nonnie states, the fans are just one speed. Depending on how the relays are activated the 12v fans are either run in a series circuit or a parallel circuit. In series they are basically seeing 6v each and run at a lower speed. When they are in parallel they each see 12v and run at full speed. One fan is also isolated and will run full speed in one instance.
