Electric Fans - Pin 33
#115
So it turns out I'm not so bright. Got with Wheatley tonight, and it turns out it had worked all along. I kept expecting the fans to kick on when I started the truck up with the AC blowing, however since the fans are turned on with temps, they wouldn't kick on until the engine reaches temp. I was too impatient and too not smart to realize that, so when they didn't kick on after a few minutes, I thought something was bunk, but they just hadn't reached their trigger temp yet.
Thanks Charlie!
Thanks Charlie!
#119
If you wire it up right,, you can command them to come on high
On the harnesss ive seen, when the compressor clutch engages, it triggers the relay.. Sometimes it triggers it alot and heats up the relay. i had one melt.
So i rewired it and let the PCM turn them on high and low.
#120
Those of you using HPT(beta) on a 99-02, how are you reassigning pin33 from the recirc to fan2? I do not see a place to reassign it like mentioned earlier in this thread. Also, regardless of tuner, what happens to the recirculation button/function on the A/C? Does it default open or closed? I really don't want to loose switching of fresh/recirc air.
