Electric Fans - Pin 33
Old Apr 11, 2010 | 12:01 AM
  #111
TX Tahoe Z71's Avatar
Going to bed so I really, really ghetto rigged it using the only thing useful I could find...
I thought the cream color accented my engine bay, Martha Stewart would be jealous.
Old Apr 11, 2010 | 12:17 AM
  #112
brent5631's Avatar
Lol. Same thing happened to mine so i got two single throw switches and temporarily mounted them in the cab.
Old Apr 11, 2010 | 04:44 PM
  #113
And the GM part number for the OEM 05 efan screws is 11516931. They were about $4 each and you need two. I got them for ease of install and to make it look factory.
Old Apr 11, 2010 | 07:55 PM
  #114
Atomic's Avatar
I have a gauge for that
this is awesome
Old Apr 15, 2010 | 11:49 PM
  #115
So it turns out I'm not so bright. Got with Wheatley tonight, and it turns out it had worked all along. I kept expecting the fans to kick on when I started the truck up with the AC blowing, however since the fans are turned on with temps, they wouldn't kick on until the engine reaches temp. I was too impatient and too not smart to realize that, so when they didn't kick on after a few minutes, I thought something was bunk, but they just hadn't reached their trigger temp yet.
Thanks Charlie!
Old May 12, 2010 | 05:17 PM
  #116
SnakeOiler's Avatar
So I take it that the HPT beta (maybe not beta now) will work on an 02 PCM for tuning pin 33?
Also, what version of EFILive works for doing this tune?
Old May 12, 2010 | 05:53 PM
  #117
KySilverado's Avatar
Yes, a HPT Beta version will work the fans. Not yet in a release.
Old May 13, 2010 | 09:21 AM
  #118
nonnieselman's Avatar
All the versions of EFILive will work..
Old May 13, 2010 | 09:24 AM
  #119
Originally Posted by GMCtrk
I wasn't aware you could command the high setting? On EFI live you cannot. Highs only come on when the A/C compressor pressure reaches a certain parameter.
If you wire it up right,, you can command them to come on high
On the harnesss ive seen, when the compressor clutch engages, it triggers the relay.. Sometimes it triggers it alot and heats up the relay. i had one melt.
So i rewired it and let the PCM turn them on high and low.
Old May 29, 2010 | 09:46 PM
  #120
BigKID's Avatar
Those of you using HPT(beta) on a 99-02, how are you reassigning pin33 from the recirc to fan2? I do not see a place to reassign it like mentioned earlier in this thread. Also, regardless of tuner, what happens to the recirculation button/function on the A/C? Does it default open or closed? I really don't want to loose switching of fresh/recirc air.
