Easy ABS Delete
Old Jul 11, 2016 | 06:32 AM
SLOPONY's Avatar
I went this route. Thanks to the info in this post, I was able to get the module out easily, and re link the lines.
I did a few things differently though. I installed a line lock in the front line at the master, and I also installed factory 05-07 rear drum brakes. So because I did the drums, I also installed an adjustable proportioning valve, and a 10 pound residual pressure valve in the rear line. I have bled it and have no issues, but I have not driven it yet to adjust any thing.
The whole thing went pretty well, no issues to speak of.
Old Jul 13, 2016 | 04:11 PM
2002_Z28_Six_Speed's Avatar
I'm doing both of these mods when I got the time. Don't mind technology actually but hate picking up the pieces due to things being engineered to fail.
Old Jul 14, 2016 | 10:56 AM
SLOPONY's Avatar
Amen to that. I bought the truck a year ago, and the abs didnt work. Changed all the brake lines, both wheel bearings and sensors, double checked everything, ABS module functioned ok with a scan tool, yet, it never worked while driving and the dash light was still on, and never went off. Now I know what to expect while braking, and no random surprises!
Old Aug 2, 2016 | 08:50 PM
stueber68's Avatar
Can the ECM and BCM be flashed to be inop? I would like to do this without deleting the brake lamp that is also used for the park brake.
Old Aug 2, 2016 | 09:49 PM
ecir45's Avatar
the brake light doesn't light for this mod, the abs does.
Old Aug 4, 2016 | 07:59 PM
druff's Avatar
why not pull the fuse?
Old Aug 6, 2016 | 12:32 PM
stueber68's Avatar
The relay intermittently fails on mine and it sets off both lights when it does. Unplugging the module and resetting codes did not keep either light off. Neither did removing the fuse. As for as I have seen, the ECM wants to see a reference regardless.
Old Aug 8, 2016 | 07:02 AM
SLOPONY's Avatar
I just fired my 01 up the other day after all winter and summer on jack stands. My brake setup works awesome, and I do not have the red brake warning lamp on, just the yellow ABS light.
Old May 14, 2018 | 11:28 PM
Solohopper's Avatar
Registered User
Has anyone required the brake lines so they don’t go so far back in the frame. At least the front brakes? Seems like a lot of brakeline can be eliminated if you just go straight to the calipers. Just cut and reflare as needed or purchase new lines. They are cheap enough.
Old May 15, 2018 | 08:41 PM
MikeGyver's Avatar
To me, it seems the work to benefit ratio of that mod would be 100% to 0%.
