E-fans Help! Staying on after ignition off
#22
LS1Tech Whore
Turn your ac on wide open and see if it comes on after 30 seconds or so. Both of my fans come on low together when idling and ac on normal, but if I kick it on max after 20-30 seconds it will pop them on high. There are quite a few ways the fan harness can be wired up. My harness is a 3 relay harness though and I think the pcm4less harness is a 2 relay which I belive controls the fans seperately.
#25
LMAO! It happens. I chased down a wiring problem for 2 days on my boat and it was a fuse. It was mounted on the starter under a rubber cover. I just stumbled across it.
Glad you got it going!
