Doors unlock when key removed
Old Jan 20, 2013 | 03:18 AM
CashDudeHomie's Avatar
Default Doors unlock when key removed
Does anyone know what wires tell the BCM when the key is pulled out? I just did some work around the steering column, and now it doesn't seem to detect when I pull the key out.
Yes I know how to reprogram it to unlock one door, both, or neither.
Is it the small connector that plugs in on top of the tumbler?
Old Jan 20, 2013 | 03:50 AM
Suburbazine's Avatar
I think so, yes. The other small wire is for the Passlock system.
Old Jan 20, 2013 | 04:07 PM
Ferocity02's Avatar
My truck has never done this. Is it an option or something? Mine is an '01 Silverado 1500 LS, 2wd, 5.3L.
Old Jan 21, 2013 | 01:14 AM
Check the manual if you still have it. You pull the turn signal lever toward you, go key on, key off, key on, key off. Release lever. Then push lock, unlock, unlock on the door. Voila.
Last edited by CashDudeHomie; Jan 21, 2013 at 03:24 PM. Reason: had code backwards
Old Jan 21, 2013 | 11:47 AM
Ferocity02's Avatar
Originally Posted by CashDudeHomie
Check the manual if you still have it. You pull the turn signal lever toward you, go key on, key off, key on, key off. Release lever. Then push unlock, lock, lock on the door. Voila.
Just did this this morning, works great! Except there are four options you can select by pressing the lock/unlock button in the correct order. I did the factory setting where it locks all doors once over 15mph, and unlocks all doors when the key is removed. Never knew my truck had this option
Old Jan 21, 2013 | 01:46 PM
TIM Z's Avatar
11 sec. Truck Mod
Yeah no **** you learn something new everyday , thanks .
I thought only steering wheel controls in 03' up gave you this option , cool to know.
Idryfly5
Sep 2, 2022 08:55 PM
FlyingLow
Nov 24, 2015 10:05 AM
Justin87gn
Sep 10, 2015 12:06 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
