Door gap adjustment. ??
Old Nov 23, 2007 | 01:29 PM
chromeplated500's Avatar
Default Door gap adjustment. ??
Ive got a 1992 chevy truck. i need to open up the top of the door gap about an 1/8th inch. any ideas or help.
because it seems that everything is welded on and im stumped.
Any ideas or suggestions??
Old Dec 8, 2007 | 12:42 AM
samcolt's Avatar
If it's welded and you you need an eighth all the way across the top, I don't have a clue. If you just need an eighth at the rear end a 2x4 usually works.
I'm serious. Open the door and position a tilted piece of 2x4 at the top rear (so that it will force the door down when you close it. Be careful how you position the wood .) and close the door with a sharp push just before it meets the wood. DON'T slam the door. If it doesn't move the first time try again with a little more quick force.
The sharp movement against the wood works better than trying to pry or force it slowly. They actually used this method in the factories a looonng time ago.
Good luck.
Old Dec 8, 2007 | 12:43 AM
CHEVRACER83's Avatar
is the gap at the bottom too big??
rumblebox
Oct 29, 2015 10:35 AM
BCraven1018
Oct 1, 2015 08:22 PM
trxmxzx
Sep 29, 2015 07:42 AM
RS/SS 4.8
Sep 17, 2015 09:17 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
