Djm flip kit issues
Old Nov 10, 2015 | 06:56 PM
melon07's Avatar
Default Djm flip kit issues
1999 2wd rcsb 4/6 drop
Has anyone had issues with breaking u-joints after installing the kit. My pinion angle is spot on, but after a test drive it vibrates like crazy. Thinking maybe my u-bolts arnt holding the rear end in place. Some pics or advice would be great
Old Nov 10, 2015 | 07:03 PM
GMCtrk's Avatar
How is your driveshaft length?
Old Nov 10, 2015 | 07:36 PM
melon07's Avatar
The kit came with plates that have offset holes that move the rearend to makeup the new driveshaft length. However I could have them backwards. I'm assuming the rear needs to be moved forward when lowering.
Old Nov 10, 2015 | 07:41 PM
GMCtrk's Avatar
I think you've got it backwards
Old Nov 10, 2015 | 07:52 PM
02singleturbo's Avatar
Correct
Old Nov 11, 2015 | 05:23 PM
melon07's Avatar
Thanks guys
Old Nov 14, 2015 | 10:10 AM
melon07's Avatar
I checked my brackets today and I have them setup to push the rear slightly back from the transmission. Just like the instructions say. Could it be possible that my u-bolts aren't holding the rear from twisting? I'm stomped
Old Nov 19, 2015 | 05:36 PM
melon07's Avatar
Anyone?
Old Nov 21, 2015 | 09:49 AM
TXsilverado's Avatar
1 or 2 piece driveshaft? If 2, did you relocate the carrier bearing?
Old Nov 21, 2015 | 08:41 PM
melon07's Avatar
1 piece driveshaft. Going to have the driveshaft looked at to make sure it's balanced
