Dim Trailer lights?
Old Apr 7, 2005 | 05:18 PM
crazy3gz's Avatar
Default Dim Trailer lights?
I finally got a connector and got my trailer wires all hooked up. (the tuck didn't come with the tow package so i had to use the cut 6 wires that are pre-wired) I hooked a trailer up and the lights seem to work but are very dim. They worked fine when hooked to my friend's truck, so the problem has to be my truck. The only weird thing aside from being dim, is it has a row of 3 running lights across the back, with the hazards on these will flash. All very dim though. I put a meter on my 7 plug connector and everything works at the right time, however, it's only get like 2v. Anyone know what the hell is up? I'm going on a long trip with the trailer tomorrow and need this fixed asap. thank you.
Old Apr 7, 2005 | 06:52 PM
thunder550's Avatar
High on diesel fumes
Are the running light and brake light wires reversed? Kinda sounds like it, dim regular lights and flashing parking lights.
Old Apr 7, 2005 | 06:57 PM
ap2002's Avatar
make sure you have your ground wire hooked up good....
Old Apr 7, 2005 | 07:52 PM
kbracing96's Avatar
99% of all the dim trailer lights I have fix, had poor, bad, or nonexistent grounds. Check them thoroughly!!
Old Apr 8, 2005 | 04:44 AM
crazy3gz's Avatar
Thanks guys, you were right on the money, it was a ground related.
Choda
Jun 5, 2025 06:43 PM
Idryfly5
Sep 2, 2022 08:55 PM
carid
Oct 28, 2015 08:24 AM
fortune46x
Sep 16, 2015 08:18 AM
