Did the General make it?
George ^^^^ did just about everything there is to do with the t56 in his build. He is a good person to listen and ask about it. Guys break the clutch petal a lot, George split the firewall and tried just about every clutch option, etc. These trucks are too heavy, especially a CC. I use to dream of running a t56 setup. Now I wouldn't touch it. Too much money, too much headache, and too much down time. Power and weight just don't equate to the same thing in this case. A built t56 can handle a ton of power, but just isn't right for a 6,000lbs truck.
You sound like an excellent candidate for a ZF650 swap. Tight shift gates, super strong, bolts up to motor, etc. Some minor mounting work and body lift may be necessary.
https://www.performancetrucks.net/fo...n-swap-404105/
See the thread I started in the Drivetrain section called "T56 Swap Regrets" in which George chimmed in on his experience with the T56 in more detail. You might be OK with a stock output engine but you would probably still want an upgraded clutch assembly due to the weight of the cc which will make it harder to be a daily driver. Just some food for thought.......
Just so were all on the same page, GM/CHEVY DID make a crew cab with a manual transmission. Not sure how many of these were offered in North America, (because I have only seen the 3500 with the 6spd here), but the 2001-2006: Silverado 3500 crew cab, Silverado 2500HD Sierra 2500HD, Sierra 3500, Avalanche 2500, Yukon XL 2500 ALL had an optional manual transmission. If they came with a 6.0L it was a 5spd transmission. Those that came with the 6.6L diesel or 8.1L came with an optional 5 or 6 spd manual transmission.
for the GMT800 stuff, most of this is true, however, the SUVs ain't had a factory manual trans option since the early 90s.
99NBS half tons did offer 4.3, 4.8, & 5.3 with the NV3500 in 2-door & extended cab models, but 2000+ was just the 4.3 & 4.8, and 01+ was only regular cabs.
with the HD trucks from 00-06, you could get a 6.0 with the NV4500 or you could opt for the 8.1 or duramax with the ZF S6-650. all the HD trucks were available with manual transmissions in RC, EC, & CC models.
if you still happen to be dead-set on a t56 for the other truck, i'd recommend 4.88s in a 14bolt rear (4.56 minimum considering the blower) based on my previous research on the swap before deciding to not pay $4k for a 4x4 tail housing.
super-old thread... but okay, i'll bite.
Might not be the place for this either, but I thought the T56 was no good for towing, (which is why I'm not going with it). Probably another debate, but I thought putting a T56 into a pickup, you may as well cut off a crossmember to save some weight, drop it, and lose any off road or 4x4 options it has. You just cut off its truck nuts,
and now drive a crossover that seats less people.
It may be fast, but if you cant tow, isn't it just half a minivan with half a trunk?
noproblems209
Aug 10, 2015 06:57 PM
TX Tahoe Z71
Aug 7, 2015 03:58 AM
