Determining Head Bolts for 04
Old Jan 18, 2011 | 06:23 PM
viciousknid's Avatar
Where's the Beef?
Default Determining Head Bolts for 04
In the middle of the 04 6.0 production they changed the head bolts. How can I determine what bolts my 04 lq4 needs?
I don't have the original head bolts.
Old Jan 18, 2011 | 06:25 PM
00ChevyScott's Avatar
Wearin' da big hat
You could use a rod or something to check the lengths of all the bolt holes in the block.
Old Jan 18, 2011 | 06:28 PM
Where's the Beef?
It has 04+ new cam bearing sizes. Would that indicate the newer head bolts as well?
Where's the Beef?
Do you know the length of 1st and 2nd design bolts?
Old Jan 18, 2011 | 06:29 PM
Wearin' da big hat
1st design will have 3 different length bolts
2nd design will have 2 different length bolts
Old Jan 18, 2011 | 06:33 PM
Where's the Beef?
that'll work. I'm thinking they likely changed the cam bearings and head bolt designs at the same time so I likely need the 2nd ones.
Old Jan 19, 2011 | 01:57 PM
moes04silverado's Avatar
both GM part numbers will work with either! The first production the middle two bolts where shorter in length, the sencond production they were all the same.
word of advice - use ARP
slowlsx
Aug 10, 2015 05:33 PM
Denali08
Aug 9, 2015 04:34 PM
signguy62
Jul 27, 2015 03:42 PM
fat tony157
Jul 16, 2015 12:35 PM
