Denali cover question
Old Nov 24, 2005 | 06:08 PM
99Silver6.0's Avatar
Default Denali cover question
Maybe this topic fits this section. But.... What other little things are needed for the Denali covers to work on a 6.0 that didnt have them? I already have the little hinge on the back of the intake. Do I need some other bolts or something?
ALSO............ I have a part number here I want to make dam sure before I order it. I want the Denali cover. The one that doesnt have that wierd *** cut on the front (below). I have 15006419 for the center. Is that right?
Old Nov 24, 2005 | 08:49 PM
02BlueStepside's Avatar
I know the 99s are different for the center cover, but I would assume the sides are the same as on my 02. The sides use exsisting holes in the valve covers to attach and two studs on the manifold. The top cover mounts with the hinge thing on the back and a small bolt on the front.
The only differences I am aware of between the denali and escalade is the escalade has the creast and the denali says Vortec 6000. What cut are you talking about?
Old Nov 24, 2005 | 09:24 PM
See the cut right above the intake tube? I dont want that cover due to that. Would be a huge gap on my truck because of the way my intake tube runs to the airbox.
Old Nov 24, 2005 | 09:42 PM
SSlow 4.8's Avatar
thts the correct number for the one w/o the cut
Old Nov 24, 2005 | 09:45 PM
SSlow 4.8's Avatar
when you buy the side covers i beleive it has the screws on there already... also, i dont think you'll need anything else for it to work, the sides connect to studs on the block i beleive...
you probably already have the part numbers.. but its 15006419 (middle) 15006417 15006418 (left and right)...
Old Nov 25, 2005 | 06:35 AM
Fogle07's Avatar
the covers come with screws
Old Nov 25, 2005 | 02:29 PM
I wasn't even thinking about that cut. Any of the electric throttle body trucks will have this cut, 03+ I think. I traded my cover for a stock ss cover and it had the cut.
Old Nov 26, 2005 | 10:26 AM
budhayes3's Avatar
PT's Slowest Truck
Yea, looks like the cut is there to clear the throttle motor, which us 99-02 guys w/o traction control don't have. I didn't even realize that they made the cover w/o the cut in it...looks alot cleaner to me. The cut looks like what I had to do to my factory fan shroud to clear the K&N FIPK
Old Nov 26, 2005 | 10:57 AM
stone150's Avatar
i want this wone more than the vortex max cover just bec of the cut.
Old Nov 26, 2005 | 11:31 AM
I didnt think I was the only one who didnt like that slice on the SS cover.
