Cut rear Springs tahoe
Old May 26, 2016 | 01:09 AM
03hoe5.3's Avatar
Registered User
Default Cut rear Springs tahoe
Can you cut stock z71 rear coil springs on a tahoe the reason I don't want to buy new ones is because I just these z71 Springs and now they made the rear sit to high all I want to is about 1 spring to make the rear sit about an inch lower
Old Jul 1, 2016 | 04:47 PM
TheAutumnWind's Avatar
Im running cut z71 springs on my Nali xl, which is heavier. Took off two coils. sits @ 35" height from the street to the fender lip in the rear. I used 3/4" heater hose instead of spring isolators.
You can see how much I cut:
Old Jul 2, 2016 | 01:16 AM
Suburbazine's Avatar
You can, but you totally screw the spring progression when doing so.
Old Jul 7, 2016 | 03:16 PM
truth
My Moog coils did not appear to be progressive. OEM may be. My Ride isn't terrible.
Needs the free travel mod though.
Old Jul 7, 2016 | 06:51 PM
druff's Avatar
If you keep the spring cold while cutting, you won't mess up the spring rate as bad. Spring steel hates heat
Old Jul 7, 2016 | 07:08 PM
Well yeah... don't use a plasma torch. I slowly cut em with a grinder and oil.
Old Jul 7, 2016 | 07:11 PM
druff's Avatar
You'd be surprised how many people take torches to them. And I'd go slower than that, I'd go hacksaw
bigtodd
Jun 15, 2016 02:14 PM
Cowboy Tom
Jun 2, 2016 08:15 AM
tgui
May 12, 2016 09:35 PM
MikeD.
May 5, 2016 12:12 AM
