Curious...
It's going to be a long time before I can dyno my motor and until I can get it put into my truck but I'm really anxious to know what I could possibly run in the 1/4 mile with this setup. It's a 84 GMC Full Size single cab swb w/ a fully built 383 , TH350 & Ford 9" w/ 411 gears. 12, 13, 14 sec?? Ya know.. given the perfect variables like good launch w/ slicks, good shift points etc. etc. What if the motor puts out 400whp? 500whp? 600whp? What could it run with mild weight reduction like aluminum racing buckets, ditch stock fuel tank for 7 gal fuel cell, etc. ??
fully built 383?....N/A, power-adder? High compression? cam? It'll be hard to tell you what it's capabilities are without the vital info. If it makes 400+ hp.....should be at the very least a 13 second ride, but I'll go out on a limb and say 12's failry easily.
• 383ci Small Block Chevy V8
• 4 Bolt Main
• Forged Alum Flat Top Pistons
• Forged 5.7 Rods
• Lunati Hydraulic Cam 246 Duration / 520 Lift
• Camel Hump Heads
• Comp Cams Valve Locks w/ Lash Cap Recess
- Lock Angle: 10°
- Valve Stem Size: 11/32"
• Comp Cams Steel Retainers
- 10°
• Comp Cams Double Valve Springs w/ Damper
- Diameter 1.430", 2 Spring
- Seat Load: 132# @ 1.750"
- Open Load: 280# @ 1.250"
- Coil Bind: 1.150"
- Rate(Lbs./In.): 296#
• Stainless steel valves undercut
- 202 Intake
- 160 Exhaust
• Victor Jr. Intake Manifold w/ Air Gap
- Port Matched
- 3500-8000 RPMs
• Holley 750 Double Pumper Carburator w/ 2" Spacer
• Double Roller Timing Chain
• Mallory fuel filter canister type w/ replaceable filter
• Jegs Pro Starter 4.41:1 gear reduction 1.9HP w/ Push Button Start
• MSD Pro Billet Distributor
• MSD 6AL Ignition
• MSD Blaster 3 Coil
• MSD Adjustable Timing Control
• MSD 8.5mm Super Conductor Plug Wires
• Hedman Headers 1 3/4" Primaries to 2 1/2" Pipes w/ Flowmaster Mufflers
• Moroso 7qt. oilpan plus filter, baffle w/ trap door & windage tray
• Perma-Cool Oil Cooler 450HP
• Perma-Cool 16" Fan
• Billet Aluminum 10 Gallon Fuel Cell
- Auto Meter Fuel Level Sender
• Auto Meter Guages inside car
• Painless Wiring
• Rebuilt Turbo 350 Transmission w/ 4K - 5500 Stall
• B&M Ratchet Shifter
• Ford 9" rear end
- 411 Gear Ratio
- STRANGE Lightweight Aluminum Spool 28-Spline
- New U-Joint Girdle
I'd say 400 horse is probably pretty conservative for your combo. Probably 450 or better...Should run 12.70 ish with all things being perfect or damn near. Weight reduction and good traction should put you in the mid to lower 12's ( again, if everything is near perfect). Sounds like a really cool project. Good luck with it.
Banned
i would say with everything perfect and traction no problem low 12.S and if u spray it how much 100shout mid 11.s.my friends car run 9.4 s with close to the same set up but he does weight 2800 ur truck is about 3800 to 3900 maybe.
Sounds like a good project truck combo you have there, also got any pics? Im not running a 383 or th350 but i did pick up a few 10ths from the 700R4 swap. Ive also never got a Good full run yet, I was running shot 8mm wires, driveshaft too short so letting out before the traps, no rear brakes so only 1000rpms of stall, 90-95%throttle and i got a best of 14.21, You should be easy 13's i know i will be once i get all the little things worked out. Also the only thing off my truck is the tailgate/rear bumper an you can see my weight in sig. Keep us updated!
