This is crazy...But Humor Me
Old Jun 17, 2009 | 06:34 PM
03 BLACKOUTSSS's Avatar
Question This is crazy...But Humor Me
With alot of machining, custom mixed and matched parts, drilling and tapping, and trial and error, would it be possible to convert a 5.3L to a Bio-Diesel running motor?
Here is what I am thinking...
Short stroke crank (hopefully from a 4.8L)
Long rods
Deep skirt high compression pistons
Combination of milling the heads / block for the correct P2V clearance and compression ratio (15-16:1)
Extremely custom cam for correct valve timing
I have been tossing around a few ideas regarding the injector / glow plug situation. From what I have read, glow plugs are really only necessary on engines that are low in the compression range. 15-16:1 might be enough to negate the need all together. If not, I can drill and take a hole in the CC for an injector and put the glow plug in the spark plug hole.
I know there are other issues but I think these are the biggest...what do you guys think? Is there potential?
Old Jun 17, 2009 | 07:00 PM
Bo185's Avatar
Nope!
Truckshop's Avatar
how are you gonna control fuel flow? you gonna go direct injection? i think that is gonna be more trouble than the basic building of it.
Old Jun 17, 2009 | 07:06 PM
Bo185's Avatar
For one you'll never get the compression that high! You'll need closer to 20 to get anything out of it.
Save your time and money!
Just buy a 6.5L swap it in what ever your working on. They run great on B100 or even WVO. And get good mileage doing it!
Old Jun 17, 2009 | 07:12 PM
L7 Sierra's Avatar
Plus the block was never designed for such extreme loading. Theres a old trick of taking early GM diesel motors and going all out, and when your done you have a 500 inch race block thats good for over a 1000 horse. I don't remember if you use Olds or Poncho heads to finish the deal off.
Old Jun 17, 2009 | 07:18 PM
Snacktime's Avatar
Made in South Korea
Now I haven't heard of that to the interweb...
Old Jun 17, 2009 | 07:54 PM
Atomic's Avatar
I have a gauge for that
The block will give out long before you get it running. There is a reason diesels weigh 800+ pounds
Old Jun 17, 2009 | 08:04 PM
Wilde Racing's Avatar
How do I change this text
fuel needs to be injected at 20-40 THOUSAND psi... FYI
Bo185's Avatar
Hey my diesel only weights 350#'s!!
Old Jun 17, 2009 | 08:08 PM
Atomic's Avatar
haha, the 4BT cummins weighs 700 pounds dry
