Coolant Smell Sometimes
Old Aug 31, 2005 | 09:54 AM
JayBirdWs6's Avatar
Default Coolant Smell Sometimes
Sometimes it smells like coolant coming threw the vents when the ac is on. What would cause this?
Old Aug 31, 2005 | 10:17 AM
three83's Avatar
Could be the heater core leaking.
Old Aug 31, 2005 | 10:44 AM
02sierraz71_5.3's Avatar
cracked head or head gasket leaking is a possibility, If you pull the dipstick and notice bubbles or white stuff means youve got coolant in the oil and problems to fix
Old Aug 31, 2005 | 12:58 PM
Coban's Avatar
If the heater core is leaking that might do it, but you'd also see coolant on the ground under your truck.
Old Aug 31, 2005 | 01:11 PM
three83's Avatar
Isn't the heater core located behind the dash board mounted against the firewall. Generally that is the location and it usually make the carpet in the passengerside of the truck damp if the leak is real bad. I maybe wrong on this since I haven't had this problem in any of my Silverados.
Old Aug 31, 2005 | 01:17 PM
JayBirdWs6's Avatar
my coolant level is fine though
Old Aug 31, 2005 | 01:20 PM
three83's Avatar
If you have a pin hole in the heater core you won't loose much coolant and it would give off a slight coolant smell
Old Aug 31, 2005 | 02:57 PM
JayBirdWs6's Avatar
Hmm, i'll have to check that out
6.0l RST
Nov 23, 2015 11:30 AM
bearden86
26
Nov 15, 2015 03:58 PM
sTNT971
Sep 26, 2015 04:22 PM
BIGD4504
Jul 28, 2015 11:46 AM
