Coolant passeges help?
So I am getting ready for my FAST install this weekend. I am reading that my engine is supposed to have this front coolant passage and the rear blocked off????
Does this sound right. I am not sure whats back behind the stock intake but this is not sounding right.
This goes in upfront
Uploaded with ImageShack.us
[IMG=http://img695.imageshack.us/img695/9282/evanpics1515.jpg][/IMG]
These plugs may be needed to block rear coolant passage???
How do I change this text
They are steam tubes. G.M began blocking the rear two ports sometime after 2000 (?). Some believe the vent tube was part of cylinder 7 failure cause in boosted applications. You might spend some time researching, but in general you are fine blocking the rears off, as I mentioned they come that way from the factory.
I had planned on using the 4 way steam tube that I have on my last engine build, then I noticed that my 243 heads don't have any holes for the steam port on the back of the heads. It appears that the new cylinder heads are now unique to the right/left side of the engine.
Just curious, that's all.
