Compressed Air Question?
Hope this is in the right section!?
I was thinking today and need an answer.
Question:
If superchargers heat up the compressed air then why does my air compressor have cool air coming out?
My Answer:
I came up with the supercharger compress the air and air compessors pump the air! Is there more or am I even close?
Question:
My Answer:
Have you ever noticed the large cooling fins on the tubes of large air compressors? They create a ton of heat. If you have a compressor with piping between the pump and the tank check how hot that tube is sometime with the compressor running. Just don't grab hold of it or you will get burned instantly.
Question:
My Answer:
Question:
My Answer:
turbo/blower spins more rpms to compress air thru passages which creates the heat
Question:
My Answer:
I came up with the supercharger compress the air and air compressors pump the air! Is there more or am I even close?
Question:
My Answer:
This is the basic principle to all refrigeration.
1TrueSS,
Whenever my air compressor runs the pressure line to the tank always gets pretty damn HOT! I assume that the cool air you are getting is coming from a compressor that either has a large tank, or is just starting up. With a large tank, the hot air going into the tank has a large volume to distribute heat to, generally 10 to 40 gallons depending on compressor. This would allow the heat to be distributed through out that volume of air before leaving the tank, passing through the regulator, through the hose and nozzle, and finally hitting your hand.
At that point, the air has had some contact volume for heat loss to occur, compared with a supercharger that is generally in close proximity to the point of use of compressed air, the engine. The supercharger also does not have a large air supply tank that it is feeding air into to allow the air to have a medium to cool with, although if a inter-cooler is present in the system this would help.
I hope that I am somewhat on track with this and that I have partly answered your question. If not, I am sure someone on here with more knowledge than I will take a stab at it.
It seems like everyone beat me to it, I took to long writing my post, but like others have said it's the law of expanding gas.
Chris
Chris
Charles Law
