!Cluster problem!
Old Jan 24, 2008 | 10:36 AM
Question !Cluster problem!
ive got a 2000 silverado and the only lights that come on are PRND321 lights
tach, speedo, fuel, oil pressure. Any possible solutions?
Old Jan 24, 2008 | 10:55 AM
leochevy2001's Avatar
probably need to change out the bulbs.
does the message center and all warning lights work?
Old Jan 24, 2008 | 10:56 AM
outlawz2004's Avatar
Yeah, go to ebay and get another one. I think on those models you can replace the bulbs with LEDs.
Old Jan 24, 2008 | 10:59 AM
yes everything works except for the lights. How would i go about replacing these lights.
Old Jan 24, 2008 | 11:59 AM
GTOsRamairSilverado's Avatar
isn't it kinda wierd that all the lights would go out at the same time ??????
Old Jan 24, 2008 | 12:18 PM
The bulbs are a 194 bulb in a bulb holder. Remove them by a half turn and take the 194 out and oua new one in it...and you'll be off to the races.
Old Jan 24, 2008 | 07:16 PM
KeukaZ71's Avatar
where you able to get the bulbs out yet?
a few of mine went out on the AC recirculating buttons. also, speed 1 went on my AC/Heat. then a month later speed 2 doesn't work. i either get blasted with hot or cold air depending on the season
Old Jan 28, 2008 | 03:50 PM
Speedextreme's Avatar
O.K. Casey, that other type "switch" on the headlight switch panel. Turn that UP, you know the one that if you go all the way up turns the dome light on? Hence your gauge light dimmin switch was all the way off!!! Sheesh I can't believe you guys didn't think of this!!! heh heh heh.
Seriously if that isn't it, then yah, any local parts store will have the #194 bulbs. And if memory serves me correctly there is like 8 or 10 in the cluster itself. So get 12 and call it good.
Now, KeukaZ71, your problem is different. Sorry to say that there aren't any replacement bulbs for the climate control area. ALL of those lights are soldered into the board. And I tried replacing them once and none of the replacements that I soldered in place lasted more than a turn on. If those are bad, I think there is someone on here has info on replacing all of these with LED's. Which is something to think about.
Laters.
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
sTNT971
Sep 26, 2015 06:27 AM
