!Cluster problem!
where you able to get the bulbs out yet?
a few of mine went out on the AC recirculating buttons. also, speed 1 went on my AC/Heat. then a month later speed 2 doesn't work. i either get blasted with hot or cold air depending on the season
O.K. Casey, that other type "switch" on the headlight switch panel. Turn that UP, you know the one that if you go all the way up turns the dome light on? Hence your gauge light dimmin switch was all the way off!!! Sheesh I can't believe you guys didn't think of this!!! heh heh heh.
Seriously if that isn't it, then yah, any local parts store will have the #194 bulbs. And if memory serves me correctly there is like 8 or 10 in the cluster itself. So get 12 and call it good.
Now, KeukaZ71, your problem is different. Sorry to say that there aren't any replacement bulbs for the climate control area. ALL of those lights are soldered into the board. And I tried replacing them once and none of the replacements that I soldered in place lasted more than a turn on. If those are bad, I think there is someone on here has info on replacing all of these with LED's. Which is something to think about.
Laters.
Laters.
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
I think on those models you can replace the bulbs with LEDs.
