Clear or Black Corners
Old Jun 18, 2006 | 11:28 PM
707DenaliGTO's Avatar
Default Clear or Black Corners
anyone know where I can still get the Black or Clear corners for my 04 Denali?
Mytightride doesn't have them anymore
thx in advance
Old Jun 18, 2006 | 11:51 PM
Post
Clear definately! Are going to go with the clear headlights as well or just the lower turn signal lamp housings?
If you do one, the other will need it too.
Jim
Old Jun 19, 2006 | 12:46 AM
Dave68RT's Avatar
look on ebay
Old Jun 19, 2006 | 01:17 AM
Thanks guys I'm planning on getting this Headlamp assembly
Old Jun 19, 2006 | 11:30 AM
Exclamation
Those look expensive!!!!!!
How much are they going for a set?
Jim
Old Jun 19, 2006 | 08:32 PM
about $329 a set
Someone ran into my Denali a couple weeks ago, no body or grille damage just the Driver side headlamp assembly bracket broke, so even with the pins in there's still play and the light level is uneven.
went to the dealer asked how much it was for one OEM headlamp assembly
$350
Old Jun 20, 2006 | 10:20 AM
02BlueStepside's Avatar
I have read from many that the aftermarket Denali style lights like that have poor light output. Some will even leak cause they are not sealed good. Personally I would keep the stockers, find a replacement for you damaged one on ebay, and clear them. Then you could get the clear corners off ebay to match.
Old Jun 20, 2006 | 01:47 PM
Beastofa327's Avatar
Like 02 said bad leaking and lighting I did it a got screwed get the OEM off ebay nad you'll be straight as for the back tailights I never had probs w/ mine so go with a black housing or a tinted spray over the OEM ones.
OHsixLS3
Nov 22, 2015 07:45 PM
cheyenne383
Nov 13, 2015 09:24 AM
thewrx
Oct 6, 2015 10:59 AM
KINGCYCLES
Oct 2, 2015 10:21 AM
Closer_2001
Sep 24, 2015 09:15 PM
