Cleaning up a block for assy...best way?
Old 01-09-2011, 04:45 PM
scooter k's Avatar
Originally Posted by 1SlowHoe
Are those cam retaining plate bolts a new thing? I've never seen them before. Do I need to replace them with the same style for clearance issues or can I use normal 10mm bolts?
All the newer blocks have the torx. I've heard other people say they were tight too. I would put new torx bolts in there. Get yourself a new torx socket and impact driver.
Old 01-10-2011, 07:40 AM
Coban's Avatar
Do the bits fit in there snug? Is is possible those screws are Torx+ screws? Or is that what you mean by "stronger Torx?"
I just came across this problem with my L92 phaser and the Torx+ screws.
Old 01-10-2011, 12:18 PM
Tootall's Avatar
get a bit that's hardened. You can buy them in singles or get a cheap set from Autozone.
Yes they sound like crap when you "crack `em" loose
Yes that plate is very "tender." I make 4 rounds when I do the cam swaps. Lock tite is NOT needed.
Some torque wrenches will goto 18lbs, . . . but they're not always accurate. Not worth it.
Old 01-11-2011, 03:43 PM
CashDudeHomie's Avatar
That looks like the new style cover where the holes are machined to accept the bolts at a low profile, so regular bolts won't work.
Old 01-11-2011, 06:00 PM
Tootall's Avatar
How long has that block been sitting for? Pretty hard to get the cam gear to get rust on it.
lucas287
31
01-12-2021 06:18 AM
mikeyjm1
17
10-29-2015 11:04 PM
kalikid06
20
10-13-2015 07:37 AM
SlvrSierra4.8
10-01-2015 09:39 PM
Quick Reply: Cleaning up a block for assy...best way?
