Check Re-Calls & Service History Here
Hey guys,
If you'd like to check the Re-Calls or your Service History & Vehicle Build of your GM Truck or Car, then you've came to the right place!
Post your questions along with your VIN # in this thread, and I'll plug them in here at work and reply with your status. I can check all re-call status, warranty status & coverage, service history along with RPO Options and etc.
I'll monitor the thread diffrent time over each day, so I should reply to your post within minutes.
Hope this helps you guys out....thanx!
Torque_Wrench
Torque_Wrench
Can you tell me what recalls or service bulletins are out there for my Tahoe and Silvy? What numbers do you need to check? The dealerships always give me a big run around when I ask whats out there that I need to get done.
Edit:
2004 Tahoe 1GNEC13Z94R239438
2000 Silvy 2GCEC19T1Y1319973
Edit:
Originally Posted by Moddoo
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
01/23/2007 073302 # B1308 - GRILLE ASSEMBLY - ONE PIECE - REPLACE 18680 miles
01/02/2007 072767 # E0436 - TIRE, BRIDGESTONE - REPLACE 17285 miles
01/02/2007 072767 # E2320 - BEARING AND HUB ASSEMBLY, FRONT WHEEL - RIGHT - REPLACE 17285 miles
01/02/2007 072767 # Z7901 - 1-DAY COURTESY TRANSPORTATION 17285 miles
03/16/2006 A79374 I Z6998 - PDI ADDS 2 miles
02/07/2006 A79374 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Edit:
Edit:
REQUIRED FIELD ACTIONS (Re-Calls)
Type Number Description Posted Date Status
RC 05037 SECOND ROW CENTER SAFETY BELT N/A Closed
SERVICE INFORMATIONAL ITEMS
SB 06047 ONSTAR HARDWARE CAN BE UPGRADED TO DIGITAL. SEE TSB 05-08-46-006. 02/21/2007 See Bulle
The second Vin# is below...
No Re-Calls on Vehicle
CLAIM HISTORY
11/25/2005 360126 # V1242 - 04007 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 63830 miles
10/06/2003 135668 0 E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 61614 miles
09/24/2001 117924 # V0609 - INSPECT BRAKE PIPE & INSTALL SPACER CLIP 48247 miles
08/17/2001 102102 0 L2040 - SEAL, EXHAUST PIPE - REPLACE 45955 miles
08/17/2001 102102 0 E9740 - GEAR ASSEMBLY, POWER STEERING - REPLACE 45955 miles
08/15/2000 086402 # C0546 - HINGE, QUARTER GLASS SWING OUT - RIGHT - REPLACE 14291 miles
08/15/2000 086402 # C0547 - HINGE, QUARTER GLASS SWING OUT - LEFT - REPLACE 14291 miles
03/20/2000 119973 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
2001 GMC Sierra 1GTEK19T71E339023
Bought it used at 78,xxx miles and never was able to find out about prior history.
Thanks Torque Wrench!
Originally Posted by Torque_Wrench
The first VIN# is below....
I guess they were being straight with me when they told me nothing was open or applied to the Silvy.
Thanks for the help Torque Wrench.........
I did have the first one done(RC 05037 SECOND ROW CENTER SAFETY BELT N/A Closed). Then I ended up putting it back the way it came from the factory again, because they leave the leather strap just chill'n there and it looked dumb. What is the second one SB 06047 ONSTAR HARDWARE CAN BE UPGRADED TO DIGITAL. SEE TSB 05-08-46-006. 02/21/2007?
Anytime friend.....just hollar.
