Chasing a tap emanating from the passenger side valve cover.
#21
Looks like its not the valve cover, no marks on the valve cover, but the rockers are definitely hitting the back of the cylinder head. It is a clearance issue.
My options seems to be getting more limited the further I dig.
Option 1 contact the builder, he may say ****** the motor out and bring it back to him.
option 2 pull out the rockers and tape the inside of the heads as best as i can and go to work with a Dremel and a shop vac
option 3 find some stock rockers and needle-less trunnion kit.
Any other suggestions ?
#22
Swap the rockers imo
#23
100% Redneck
Photo of my old LQ9 heads before assembly. These marks were from a factory camshaft and stock rocker arms. Your rollers may have even more of a clearance issue or the marks could have been left by the stock rockers
#24
Can the backside of the head where they are presumed to be hitting be worked? (Grounded down a bit)
This maybe the culprit for the valve cover knock, but would this also cause intermittent sputtering? Or as Shakenfake “IMO’d” it would be better to just go with a different rocker setup. Would something like cathedral port max effort rockers from RPM speed be better option?
#26
100% Redneck
If the rockers are barely contacting the head (like in the pic) they will clearance themselves... but yes you can work that area. There is a thread over at "Tech" showing how roller rockers can effect performance (dyno falling off at upper RPM's). The OP swapped out to a stock type setup from TSP and was surprised with the results. If you post questions over at tech there are a lot of experienced engine builders over there and questions will get more eyes.
Ls1 w Bolton’s 480 rwhp but want more
#27
toomuchjunk
07-05-2018 11:03 PM
JCunningham
05-16-2013 11:46 PM
paulandrew1417
11-03-2011 01:46 AM
