Changing Fuel Pump to Walbro 255, HELP!
Old Oct 24, 2009 | 09:57 PM
Midnight's Avatar
Default Changing Fuel Pump to Walbro 255, HELP!
Hey Does anyone have a walk-through for replacing the fuel pump on our trucks?
Also, would I need to make any other modifications to the fuel system to run a walbro 255?
Old Oct 24, 2009 | 10:05 PM
spaz1's Avatar
12 Second Club
I usually pull the drive shaft off and drop the tank down. Then you can pull the fuel pump module out the top of the tank.
Old Oct 24, 2009 | 10:24 PM
PathfinderJr's Avatar
An alternative method is to lift the bed off with a cherry picker and you've got easy access to the top of the tank.
Old Oct 24, 2009 | 11:14 PM
Midnight's Avatar
So I can just undo the straps and lower it down?
Old Oct 24, 2009 | 11:19 PM
spaz1's Avatar
12 Second Club
Yes just wait till your almost out of gas it's a lot easier to manouver. Make sure you watch the lines and wiring . I usually drop it down a bit unhook everything and then drop it down more until you can pull the unit out.
Old Oct 24, 2009 | 11:27 PM
tallChevy's Avatar
you only need to pull the drive shaft if you have the aluminum one. If you want me to I can take pictures of the top of the tank so you can see what you need to unhook.
Old Oct 24, 2009 | 11:35 PM
spaz1's Avatar
12 Second Club
I guess you could squease up there I just pull it 4 bolts and it's out of the way.
Old Oct 25, 2009 | 12:51 AM
Midnight's Avatar
Ok yeah if you could take some pictures.
Old Oct 25, 2009 | 01:03 AM
Black'Rado's Avatar
heres my install thread... https://www.performancetrucks.net/fo...d.php?t=448745
Old Oct 25, 2009 | 01:14 AM
Midnight's Avatar
Thanks Black, what about the sending unit? Does a new one come with the TSP walbro kit? Cause that's what is ******* up on mine.
