Can tech2 program speedometer gauge difference
Old Jun 23, 2013 | 02:09 AM
00ecsb's Avatar
Default Can tech2 program speedometer gauge difference
Can the tech2 at the gm dealership program the speedometer chip? I used the circuit board from my 2000 silverado in an escalade cluster I bought that ended up being bad. Well my silverado had a 100mph speedo. The escalade is 120mph. Can they program my silverado board to be 120mph?
Thanks in advance
Old Jun 23, 2013 | 02:47 AM
ak2007r6's Avatar
To my knowledge it should be plug and play and should not need any adjustments I though. Everything I have read is just plug it in and go.
Is it reading incorrectly? Have you checked it with GPS?
Old Jun 23, 2013 | 09:35 AM
00ecsb's Avatar
It's plug and play if you still have the escalade circuit board. I used the one out of my silverado cluster since the escalade one was messed up and I could keep odometer accuracy. Yes I've verified it by gps. It's definitely off.
Old Jun 23, 2013 | 09:37 AM
bobfig's Avatar
is this for an obs? also are you a v6 or v8
Old Jun 23, 2013 | 11:44 AM
00ecsb's Avatar
nbs v8 5.3
Old Jun 23, 2013 | 12:00 PM
bobfig's Avatar
ok then idk i have only had experience with obs and gauge swaps.
Old Jun 23, 2013 | 03:20 PM
1FastBrick's Avatar
Custm2500's Rude Friend
I would send it to a Gauge shop that specializes in that. My understanding is that program it and then use a different software to modify the code.
Every dealer I asked around here says they just have a Speed-O-Shop do it.
GXPJAY
Feb 13, 2022 08:15 AM
AkSSS
Mar 29, 2016 11:03 PM
TX Tahoe Z71
Sep 1, 2015 09:11 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Bluecollar Hotrods
Jul 26, 2015 09:56 PM
