Can i fit 33s
Old Jun 1, 2014 | 12:18 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Crappy old cell pic of the wife's Yukon. 2-3" lift keys with 1" coil spacers on the rear. Tires are LT285/70R17/D AT's, zero rub with zero trimming.
Old Sep 5, 2015 | 01:24 AM
Wolftrk99's Avatar
You should clear a 33x10.5 (285/70r17 or 285/75r16) with no problem may need crank torsion bars slightly if you want wider need different offset wheels....seen many of these trucks running them with no rub at all
Old Sep 7, 2015 | 03:03 PM
mikeyjm1's Avatar
Use an OEM wheel. The width and more importantly the perfect offset is where you get the fit.
I had 33/12.5/17 interco Truxxus tires on mine with no leveling kit. Only about an 1.5" crank in the front and some minor trimming.
Through the years I've nearly begged people who are hell bent on wasting money on keys/leveling kits/whatever, not to waste the money before the try without.
I'm deployed so I'll have to search for a pic but it looked great and worked and cost no more than a little time with a tape and a wrench.
Old Sep 7, 2015 | 03:24 PM
mikeyjm1's Avatar
Found a few...
Old Sep 7, 2015 | 04:03 PM
Wolftrk99's Avatar
Have seen oe wheels with 33s rub sway bar slightly on turns... Goin with slighly less offset helps in that case... Wholeheartedly agree with leveling keys/kits, just need be careful with the torsion adjusters have seen bolts break without relelasing some of the tension...
simman22
Jan 21, 2017 10:27 PM
FlowmasterMufflers
Nov 24, 2015 01:00 PM
SloSVO
Sep 12, 2015 06:56 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
11MPG
Sep 8, 2015 04:52 AM
