Cam or Convertor first
Old Oct 5, 2011 | 12:28 PM
2000chevysilverado's Avatar
Default Cam or Convertor first
What would be best to get first I was thinking of just doing a z06 cam at the most but dont know if a better convertor would be the first thing to get, also if anybody knows if a lq4 throttle body would fit on a 5.3 intake let me know would like to get some more air flowing. thanks for the advice
Old Oct 5, 2011 | 12:43 PM
1slowz71's Avatar
an lq4 throttle body is the same as the nbs 5.3 if its from 03 to 06 dbw , and IMHO i would do a converter b4 a cam but a real converter like a 258mm or a 245mm not no 278mm .....and then the cam ...
Old Oct 5, 2011 | 12:48 PM
pl4yboy's Avatar
Banned
Get a Circle D converter first.
Old Oct 5, 2011 | 01:49 PM
Ok sounds like a convertor first what kinda stall would I be lookn for
Old Oct 5, 2011 | 01:52 PM
06Sierra2's Avatar
for a dd truck like myself, i noticed a significant gain with my circle d 278mm even on the stock cam. obviously cam selection plays a part in the stall rating and i am thinking of going to a 258mm next time, but for a dd truck the 278mm is a great stall imo that will easily pick up a few tenths at the track and run great on the street
Old Oct 5, 2011 | 01:55 PM
dlt76028's Avatar
Converter first and if your na a z06 cam is a poor choice.
Old Oct 5, 2011 | 02:56 PM
GMCtrk's Avatar
The common answer here is converter first.
I've had it both ways: stock cam/3600 converter and stock converter/aftermarket cam. Ive enjoyed the cammed setup more, and if it wasnt for a little more noise no one would know it wasnt stock. But, I do want to try a different torque converter setup.
I will tell you that both ways can work very well, provided your cam spec is appropriate. A good tune is a must either way.
Old Oct 5, 2011 | 03:10 PM
I've done a cam no convertor this time I will go the other way around with a 3200 stall now to figure out which is best to buy
Old Oct 5, 2011 | 04:01 PM
1slowz71's Avatar
no dought i did a 278mm 1st and it was tons of fun then i jusped to a 258mm..the reaso I say do a reall 1 not a 278mm its couse eventually youll go to them... when you could have boughten 1 the 1st time around and saved your self those $500 that you spent on the 278mm.
Old Oct 5, 2011 | 04:19 PM
Which would be better circle d or yank for the money and how hard is it to install a vette servo
