A/c not working at idle
Old Jun 29, 2012 | 12:51 PM
06colorado's Avatar
Default A/c not working at idle
My A/C blows cold at idle. Cools fine when any amount of throttle is given. Compressor kicks on real quick then disengages quickly after. My idle is set at 750 and if i idle it to 900 it blows cold, whats the deal?
Old Jun 29, 2012 | 12:55 PM
BigBronBrizzle's Avatar
Registered User
Sounds like its low on charge. My Truck was just a tad bit low on Freon and it would click on and off like crazy at idle... making the idle erratic.
Old Jun 29, 2012 | 01:23 PM
06colorado's Avatar
I thought that aswell so i bought the recharge kit from the parts store and it said it was good so i didnt add any, I guess i need to get a good set of gauges on it just in case
Old Jun 30, 2012 | 12:17 AM
greasemykey's Avatar
sounds like its your pressure switch to me. when it starts to "short cycle' at idle what are your pressures doing before the compressor kicks off?
Old Jul 7, 2012 | 07:17 PM
Sc00by's Avatar
How many miles are on the truck? Mine has the original clutch fan on it and when at idle when cold the A/C doesn't work too well. If its not low on charge that's what I would look into next
Old Jul 9, 2012 | 12:18 AM
1FastBrick's Avatar
Custm2500's Rude Friend
With out knowing the pressures and the out side temp its hard to say specifically whats wrong.
I found this handy chart that gives you pressures and what to look for. If you can read the pressures on the high an low with the system running this may help you.
Attached Thumbnails A/c not working at idle-ac-chart.png
ullose272
Aug 5, 2016 02:05 PM
creekrat
Aug 2, 2015 01:27 AM
fillpot
Jul 26, 2015 07:21 PM
atxlt
Jul 20, 2015 11:06 PM
