a/c button light flashes
Old Aug 23, 2010 | 11:27 AM
CaLI87's Avatar
Default a/c button light flashes
I have a 08 silverado and when I push the button for the ac all it does it blinks a couple of times and the clutch won't even spin, it has freon what can be wrong
Old Aug 23, 2010 | 12:20 PM
PathfinderJr's Avatar
Stupid question, but is your fan on? If I forget and have my fan on '0', ie off, and I press my a/c button, it'll blink and do nothing. The fan motor has to be running for the a/c to engage and turn on.
Old Aug 23, 2010 | 12:54 PM
CaLI87's Avatar
Stupid answer but thanks anyway..
Old Aug 23, 2010 | 01:24 PM
terravast4's Avatar
didnt sound stupid to me......you asked.
Old Aug 23, 2010 | 02:15 PM
CaLI87's Avatar
Fan is on, has freon checked wires I have no clue why is not engaging
Old Aug 23, 2010 | 03:03 PM
I meant that my question to you was stupid, as in I figured it was trivial but sometimes the easiest things are overlooked.
Old Aug 23, 2010 | 04:10 PM
CaLI87's Avatar
Sorry about that man just a misunderstand anyway anybody else has ever experience this?
Old Aug 24, 2010 | 08:16 AM
slpsilverado's Avatar
I do this kind of crap all the time. Like killing a fly with a shotgun, when all you need is a flyswatter.
Old Aug 26, 2010 | 12:18 AM
04Silverado5.3's Avatar
There is a bulletin for this.
#07-01-38-006: Information for Vehicles with HVAC Control Module A/C Indicator Blinking Due to Low Battery State of Charge - (Aug 20, 2007)
Subject: Information For Vehicles with HVAC Control Module A/C Indicator Blinking Due to Low Battery State of Charge
Models: 2007-2008 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007-2008 GMC Sierra, Yukon, Yukon XL
with Manual Temperature Control HVAC System (RPO CJ3)
An Air Condition (A/C) button on the Heating, Ventilation and Air Conditioning (HVAC) control module may blink when the A/C system is activated. The blinking indicator will turn to a solid light after cycling the A/C button or ignition key.
This condition may be caused by a low battery state of charge on a PREVIOUS ignition key cycle. This condition may be due to situations were an unsold vehicle is parked for long periods of time as part of a dealership's unsold inventory. The A/C indicator begins to flash If the battery voltage falls below 9.5 volts. The low voltage condition may occur during an engine crank or if the vehicle is parked and a normal battery state of charge is not maintained.
Run the vehicle to charge the battery or connect a battery charger. (If the charging system is operating as designed , the battery surface charge should indicate 12+ volts.)
Do Not Replace the battery, HVAC control module or ECM.
If the A/C indicator continues to blink, use the Tech 2® to help determine the cause.
• Connect the Tech 2 and build the vehicle.
• Select Powertrain.
• Select Engine Control Module (ECM).
• Select Data Display.
• Select Cooling/HVAC data.
• Make sure that there has been an A/C request signal.
• History should indicate any causes.
If necessary, refer to SI for further information on HVAC system diagnostic procedures.
Old Aug 26, 2010 | 04:45 PM
CaLI87's Avatar
Thanks a lot man that solved my problem, low voltage was causing it. thanks
legerwn
56
Nov 15, 2015 10:21 PM
Brandonlflr12
14
Sep 16, 2015 12:44 AM
MA$TER_E
Sep 9, 2015 03:14 PM
Hpinnovate
Sep 4, 2015 02:28 AM
