Budget Brake question.
Old Feb 23, 2015 | 01:34 PM
sonicblue4.6's Avatar
Default Budget Brake question.
Can i use these for my budget Brake upgrades?
http://www.ebay.com/itm/Front-Brake-Calipers-Drilled-Slotted-Rotors-Ceramic-Pads-Covers-Left-and-Right-/271711876230?&_trksid=p2056016.m2516.l5255
http://www.ebay.com/itm/Rear-Brake-Calipers-Drilled-Slotted-Rotors-Ceramic-Pads-Covers-Left-and-Right-/301378688922?&_trksid=p2056016.m2516.l5255
Old Feb 24, 2015 | 01:03 PM
dirt track racer 81's Avatar
Sure. Stock are plentyful.
Old Mar 4, 2015 | 11:59 PM
gamble686's Avatar
Can you? Yes. However, the best budget upgrade for the truck in your dig would be simpler going to the newer larger front brakes. It's a simple and affordable upgrade. You go from 11" to 13" rotors.
Old Mar 5, 2015 | 09:02 AM
What all is involved in the upgrade you speak of. Maybe I was looking into what I was trying to do all wrong.
I definatly want to get a extra set of calipers to have powder-coated cause with my new wheels my old ones are ugly!!!!!
Old Mar 5, 2015 | 01:43 PM
N/ALS1's Avatar
You get the 13" rotors and loaded calipers from an '05 truck which come with brake pads and the mounting bracket for the 13" rotors. That's the year they went to drum brakes on the rear and larger discs up front.
If you have rear disc like my '00 rcsb has you can do the Tahoe dual piston calipers for the rear. There's a sticky I believe. I'll look and link it to this reply.
Here's the link: https://www.performancetrucks.net/fo...verado-467040/
Old Mar 5, 2015 | 01:55 PM
I thought that was what I was doing with the links I had posted above. Maybe I was looking at it all wrong. My truck has Disc brakes in the rear also. I had searched and read the thread you mentioned. Guess I screwed up what I was thinking about doing lol.
Old Apr 7, 2015 | 07:30 PM
06boosted5.3's Avatar
so since I have an 06 rcsb my truck should have the 13" rotors? have you seen the ssbc kit that uses 14" rotor? my only concern was it uses a stock caliper which I don't see if there isn't added contact how does that help?
Old Apr 22, 2015 | 03:21 PM
bobfig's Avatar
mostly leverage.
RustyD
May 23, 2016 07:04 PM
wretched73
Oct 28, 2015 09:21 PM
turbo6c3
Oct 5, 2015 06:11 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
xxloudogxx
Sep 28, 2015 12:30 PM
