Blazer not running...what could it be???
Old Nov 25, 2004 | 05:57 PM
Matt D's Avatar
Retired Street Racer
Old Nov 26, 2004 | 02:48 PM
Matt D's Avatar
alright guys, it is a fuel problem...if i spray starting fluid into the tb it starts, but dies out b/c of lack of fuel. the fuel pump is humming, i can hear it. what do you think
Old Nov 26, 2004 | 03:02 PM
Well, just because it is humming doesnt mean it is pumping the correct pressure. But if it is pumping correctly, then you are looking at either a fuel pressure regulator or the injectors. You can get a rebuild kit for the regulator for about $25, and the injectors run about $40 a piece at your local AAP.
Ryan
Old Nov 26, 2004 | 03:28 PM
Matt D's Avatar
i took off the fuel filter, and that might be the problem...going to napa to get a new one, gonna try that
Old Nov 26, 2004 | 04:40 PM
Matt D's Avatar
nope, not the fuel filter, it just isn't getting feul to the throttle body
Old Nov 27, 2004 | 07:09 AM
see above!! lol, let me know what it turns out to be.
Ryan
Old Nov 27, 2004 | 01:20 PM
Matt D's Avatar
thanks juggernaut, it is the fuel pump, it is barely pupming fuel past the filter, it is a steady stream, but it is not spraying at the psi it need to. thanks again, matthew
Old Nov 27, 2004 | 08:11 PM
Ah that stinks, gotta drop the tank and everything. You can do it!
Ryan
Old Nov 27, 2004 | 11:49 PM
Matt D's Avatar
yeah, if i can change plugs on my camaro, i can drop the tank and swap out fuel pumps on the blazer. Damn, that is so sad
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
X_Racing1
21
Mar 30, 2016 02:37 PM
TURBHOE
Mar 25, 2005 05:37 PM
