What is the best way to make a little clearance for fat drag radials? I put some 315/60s on my 06 with a flip kit and the driver side rubs just a tiny bit over bumps and stuff.
Should I heat it up and roll the inside lip or just trim it with a cutoff wheel?
Check the bed placement versus the cab, i have seen them be a little off side to side multiple times. Very common if someone has pulled off to do a fuel pump or something and just slapped it back on and ran down the bolts without checking.
