Best way to add clearance for drag radials?
What is the best way to make a little clearance for fat drag radials? I put some 315/60s on my 06 with a flip kit and the driver side rubs just a tiny bit over bumps and stuff.
Should I heat it up and roll the inside lip or just trim it with a cutoff wheel?
FFDP (11-21-2017)
Here is what the baja guys do, it actually looks pretty decent imo.
How To: Pull Bed Sides - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Make sure you have the google chrome photobucket fix addon so you can see the pictures in the thread.
Check the bed placement versus the cab, i have seen them be a little off side to side multiple times. Very common if someone has pulled off to do a fuel pump or something and just slapped it back on and ran down the bolts without checking.
