Best way to add clearance for drag radials?
Old 11-21-2017, 08:27 AM
turbo_outlaw's Avatar
Default Best way to add clearance for drag radials?
What is the best way to make a little clearance for fat drag radials? I put some 315/60s on my 06 with a flip kit and the driver side rubs just a tiny bit over bumps and stuff.
Should I heat it up and roll the inside lip or just trim it with a cutoff wheel?
Old 11-21-2017, 08:34 AM
Old 11-21-2017, 11:18 AM
Still moddin'
Reckless's Avatar
Looks good!
I plan on taking the long route...get rid of leaf springs, mini-tub, narrow rear end, convert to 5-lug
Old 11-21-2017, 12:16 PM
I have a gauge for that
Atomic's Avatar
Easiest way is raise the truck up.
FFDP (11-21-2017)
Old 11-21-2017, 12:56 PM
ILuvJDM's Avatar
Rent a fender roller or have it done professionally. Don't cut the lips off, that's ghetto
Old 11-21-2017, 04:08 PM
3wide's Avatar
This above....We have used a baseball bat but if you like your body and paint maybe not...
Old 11-21-2017, 04:15 PM
GM1697's Avatar
Here is what the baja guys do, it actually looks pretty decent imo.
How To: Pull Bed Sides - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Make sure you have the google chrome photobucket fix addon so you can see the pictures in the thread.
Old 11-21-2017, 10:20 PM
rennat_2006's Avatar
Check the bed placement versus the cab, i have seen them be a little off side to side multiple times. Very common if someone has pulled off to do a fuel pump or something and just slapped it back on and ran down the bolts without checking.
Old 11-21-2017, 11:11 PM
Jake75's Avatar
Had mine rolled. I have a 4/6 drop
Old 11-22-2017, 03:27 PM
Vortec350ss's Avatar
I'm going to be in a similar situation... they do look sweet though!
Which tire is that you went with?
