Belt squealing problem
Old May 12, 2010 | 09:05 PM
OneBadSSS's Avatar
Default Belt squealing problem
Ok, I just recently bought my Dad's '02 Silverado from him (truck in sig) and it's got a weird belt squealing issue. Not every time, but most times, when I turn the engine over there will be a loud, momentary belt squeal as soon as I release the key in the ignition. It does this whether the engine is hot or cold. Also, when I turn the AC on, it blows cold but the belt squeal noise happens for a loooong time at initial AC turn on (I assume as the compressor is charging the system?) and then it happens again for a few seconds each time the compressor cycles.
My question is, are these squeals the result of belts needing replacement? Or am I looking at needing to replace the tensioner pulley and possibly the entire AC compressor?
Old May 13, 2010 | 07:43 AM
8.1 HD's Avatar
Since the majority of the noise is present when the A/C compressor is on then I would target the belt that drives it and the idler pulley that maintains pressure on that same belt, the bearings tend to dry out over time due to heat exposure.
madmann26
Apr 29, 2020 09:17 AM
dsbodley
Nov 14, 2015 09:46 PM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
murderedSS
Sep 27, 2015 10:16 PM
